Older Xerox scan to file
  • iscott
    • Mar 2010
    • 344
    Trying to help a friend,
    Has an older Xerox don't have the model right now it's about a 10 year old machine. A console with a opscreen on an arm (It is not a Docutech) I'm guessing its a 60 PPM machine.
    It will not scan to file. When you run the detect Xerox scanners it will not register. I know with some of the older Ricoh's there is a program you must install to get it to scan.
    Any help is appreciated...
  • xcopytech
    • Aug 2006
    • 1794
    If you want that someone help you must post which model you friend have.
    • Daan
      • Mar 2013
      • 60
      Re: Older Xerox scan to file
      it sounds like you are trying to detect the scanner in windows like you would with a hp desktop scanner.
      xerox generally doesnt work that way, some smaller models excepted.
      You enter an entry for a ftp server or smb(windows shared folder) into the web interface of the machine, either at network scanning or in the address book (older models)
      It should be connected via network, and not via usb.
      • iscott
        • Mar 2010
        • 344
        The Model is a Work Centre 7655 not as old as I thought 7-8 years old maybe...
        • Daan
          • Mar 2013
          • 60
          guy does the whole setup, network scanning around min 6.
