workcentre 7335
  • michaelngun2121
    • Aug 2013
    • 6
    workcentre 7335
    how do I check developer and transfer belt life counters, and how do I enter service mode? anyone have a manual? This machine looks like a dinosaur.
  • adriansto
    • 2388
    Re: workcentre 7335
    Service manual in edoc format. You need pws software for use edoc.
    Why the machine look like a ... ?
    • Tek_services
      • Jul 2014
      • 22
      Re: workcentre 7335
      try this: go to LOG IN user: admin pass: 1111 and then enter
      • Tek_services
        • Jul 2014
        • 22
        Re: workcentre 7335
        i have edoc for this machine and i have pws portable full funtionally
        • Exok
          • Jun 2011
          • 750
          Re: workcentre 7335
          To enter service mode:
          Press and hold the 0 key for 5 seconds or longer. While still holding the 0, press the Start key.
          Enter code 6789 and Confirm.
          Press Machine Status button.
          Select Tools tab.
          Select System Settings.
          In the Group column, select Common Service Settings.
          In Features column, scroll down to Maintenance / Diagnostics.
          Scroll down to Adjustments / Other.
          Select HSFI counters.
          954-801 = Transfer Belt
          954-802 = 2nd BTR roller
          954-803 = Transfer Belt Cleaner
          954-804 = Fusing Unit
          954-811 = Black DV housing
          954-812 = Cyan DV housing
          954-813 = Magenta DV housing
          954-814 = Yellow DV housing
          The counters are only as accurate as the techs who have been there before you. They are reset manually.
          • michaelngun2121
            • Aug 2013
            • 6
            Re: workcentre 7335
            Select Tools tab.
            Thank you so much! awesome
