xerox workcentre 7655 firmware 040.032.53080 firmware needed
  • djwhoo
    • Aug 2013
    • 117
    can some one please get me the 040.032.53080. Thank you
    ess and net controller
  • adriansto
    • 2369
    Re: xerox workcentre 7655 firmware 040.032.53080 firmware needed
    Do you want to upgrade or reload this sys. sw. version ?
    • mntech
      • Aug 2010
      • 250
      DJWhoo is a co-worker of mine
      I believe we would need the full reload for use with PWS
      Here is what happened:
      UI Calibration was off, then the panel became non-responsive
      We tried 2 different UI's but kept getting host-to-hosts
      We ended up reloading the software with version 040.033.53050
      Machine came up and can print, but fax button isnt showing up, and when trying to copy it just says pending
      From another post I read, it sounds like you cannot upgrade from 040.032.xxxxx to 040.033.xxxxx without upgrading hardware
      Currently System and CCM are at 040.032.56080 and NET and UI are at 040.033.53050
      THANKS!
      • adriansto
        • 2369
        Bad move to try upgrading from 40.032 to 40.033 without you know what you are doing.
        Certainly you need full software version 40.032.53080 and try to restore step by step all systems.
        Send me mail at stoadis@gmail.com.
