510dp problem!!!!!!!!
  • walidcharifi
    • Feb 2011
    • 379
    hi freinds
    my 510dp wideformat problem
    video
    <br>
  • xcopytech
    • Aug 2006
    • 1794
    Re: 510dp problem!!!!!!!!
    did you check pins and grid on charge scorotron?
    • walidcharifi
      • Feb 2011
      • 379
      salvation
      thank you for answer
      I checked but still same problem
      • Iowatech
        Not a service manager
        • 3930
        I am the newest of noobs here for Xerox, and also I currently have seen exactly zero Xerox wide format printers.
        For what it is worth though, based on what I've seen on the machines I have worked on for some time, there most likely is a buildup of toner in the paper path somewhere before the fuser. From what I've seen it is usually is somewhere around the drum, and if you are able to vacuum that area with a vacuum that can handle toner, and can do that without damaging the drum (wide format drums are very expensive to replace) it will probably provide you with temporary relief. Then you just have to find out why that toner was there.
        • walidcharifi
          • Feb 2011
          • 379
          I change the bar erase another machine
          and solve the problem
          • tonerspot
            • Nov 2008
            • 79
            u have to clean charge grid and corotron, or replace it.
            • walidcharifi
              • Feb 2011
              • 379
              • xcopytech
                • Aug 2006
                • 1794
                replace charge scorotron.
                • Tek_services
                  • Jul 2014
                  • 22
                  developer unit inside, look for toner blade
                  • walidcharifi
                    • Feb 2011
                    • 379
                    • walidcharifi
                      • Feb 2011
                      • 379
                      HI FREINDS
                      NO HELP...............??
                      • walidcharifi
                        • Feb 2011
                        • 379
                        not resolved ..............................help me plz
