Hi all. Not sure if this is the right place to ask. I have a fleet of 70+ 7855's and I want to schedule a reboot over the weekend automatically. I found a code for PowerShell to do this, but it doesn't seem to work.
Firstly, anyone PowerShell savvy know why? PS just says completed, but the machine is still on. Secondly, is there another way? I can'y seem to find one, but i haven't asked here yet.
Any help much appreciated.
Andy
Code:
$CookieContainer = New-Object System.Net.CookieContainer function SendGET([string]$url) { [net.httpWebRequest] $req = [net.webRequest]::create($url); $req.Method = "GET"; $req.Accept = "text/html"; $req.CookieContainer = $CookieContainer; [net.httpWebResponse] $res = $req.getResponse(); $resst = $res.getResponseStream(); $sr = new-object IO.StreamReader($resst); $result = $sr.ReadToEnd(); return $result; } function SendPOST([string]$url, [string]$data) { $buffer = [text.encoding]::ascii.getbytes($data) [net.httpWebRequest] $req = [net.webRequest]::create($url) $req.method = "POST" $req.ContentType = "application/x-www-form-urlencoded" $req.ContentLength = $buffer.length $req.KeepAlive = $true $req.CookieContainer = $CookieContainer $reqst = $req.getRequestStream() $reqst.write($buffer, 0, $buffer.length) $reqst.flush() $reqst.close() [net.httpWebResponse] $res = $req.getResponse() $resst = $res.getResponseStream() $sr = new-object IO.StreamReader($resst) $result = $sr.ReadToEnd() $res.close() return $result; } # Request to get session id $x = SendGET ("http://10.64.135.52/properties/authentication/login.php"); # Post login to get new session id $x = SendPOST ("http://10.64.135.52/userpost/xerox.set") ("_fun_function=HTTP_Authenticate_fn&NextPage=%2Fproperties%2Fauthentication%2FluidLogin.php&webUsername=admin&webPassword=1111&frmaltDomain=default"); # Post reboot command with loggedin session id $x = SendPOST ("http://10.64.135.52/userpost/xerox.set") ("_fun_function=HTTP_Machine_Reset_fn&NextPage=/status/rebooted.php");
Andy
