Workcentre Pro 65 "Toner Control Patch Low"
  • wmarkland
    • May 2008
    • 24
    I am now receiving an error 9-334 stating "Toner Control Patch Low". Just wondering what this is. Thanks.
    I am also receiving error code 9-380 stating "Transfer Arc Fault"
  • Silvio Ribeiro
    • May 2008
    • 34
    It may be the BTAC sensor dirty (Unit is in Reveladora facing copy of the module) or full copy of the module (he is pra 100K - 300K) you must change
    • wmarkland
      • May 2008
      • 24
      workcentre pro 65
      What and hhere is the batc sensor?
      • Silvio Ribeiro
        • May 2008
        • 34
        sta_silvio@yahoo.com.br
        • technic
          • May 2008
          • 29
          The btac sensor is mounted on the developer unit,so you need to get the developer unit out of the machine to have access to it, this sensor faces the xerographic module and read the patches on the belt. This sensor is 2 1/2 inches long more or less,mounted on a metal clip attached to the developer unit. You can run a xerographic routine from the touch panel to test the xero system.
