Xerox DC250 erro 093-317
  • neetosena
    • 6
    good afternoon
    Please need some help, recently the engine began to accuse this error 093-317, searching the internet I noticed that it was on the black toner, follow some tips to Zera the NVM, but after some time the error back again.
    Detail printing is clear, it seems that the toner is not falling in the reservoir.
  • InterfaceP
    • Jun 2013
    • 488
    Re: Xerox DC250 erro 093-317
    You shouldn't be able to tell if the toner reservoir is full.
    The toner motor could be binding or may be out.
    Enter component control [093-009] (Black Dispense Motor). Select Start
    You should hear it running. If not check the connections the dispenser motor.
    If it's bad you may consider someone with experience, replacing it will be a difficult, it's buried behind a lot of components.
    • neetosena
      • 6
      Good afternoon !!
      Thanks for the reply, but I have a doubt.
      How do I do this test, I have to access the NVM?
      • adriansto
        • 2384
        Originally posted by neetosena
        Good afternoon !!
        First you need service manual to read the proper procedure.
        • InterfaceP
          • Jun 2013
          • 488
          Good afternoon !!
          Log in the the same way you did when accessing the NVM values instead look for component control.
          Enter [093-009] and push the start button.
          • neetosena
            • 6
            Actually I selected the NVM Read / Write?
            Put this and the following information:
            The selected NVM can not be read when
            Now what?
            Thank you
            • InterfaceP
              • Jun 2013
              • 488
              Now what?
              Thank you
              No not NVM. Component control. Look for it, I believe it's under IO check.
              Changing NVM values is not a good idea unless you know what you're doing.
              Good luck.
