Xerox WC 7242 print with small points on all page need help
  • 1mcfilhos
    • Mar 2013
    • 32
    Hello
    I have one problem with my Xerox when i print it apear small points on all page like whatermark but when i make a copy the page is clean without the points
    i have add one printing page with the small spots
  • adriansto
    • 2375
    Re: Xerox WC 7242 print with small points on all page need help
    Try to print using usb port.
    Same points ( spots ) on page ?
    • 1mcfilhos
      • Mar 2013
      • 32
      hello
      i have tryed but same printing if you see my image and you zoom it you will see the poists that is like a whatermark the same for all page
      can you help
      • adriansto
        • 2375
        I see it's a repetitive pattern of spots.
        Can be a noise from PC network but if this pattern exist already, when you print using machine usb port, then is something with internal electronic boards or internal hdd. Try to reseat the memories dimm and all connectors inside machine. Never seen this pattern before.
        • Iowatech
          Not a service manager
          • 3930
          This might be stupid, but could someone have set up a "default watermark" on that machine?
          On the pictures it looks a little like the repeating pattern has somewhat of an alphanumeric pattern. As such, that's something I'd check anyway.
          Sorry if that was a waste of time.
          • 1mcfilhos
            • Mar 2013
            • 32
            hello
            one thing that i noted now
            when i print black the page is clean only when i print the colors
            and no whater mark
            • NeoMatrix
              Senior Tech.
              • 3514
              Are you printing from a PDF file or maybe off the web HTML?Is it the same for other PC's connected to the printer?Looks like an image or author copyright encoding. You might not see it until the screen colours are converted to nearest PCL colour.
              • Nildera
                • Nov 2014
                • 13
                I have similiar problem but my printer printingimg143.jpg this page every time when I start a new job.
                also printing small points...
                any one can help me please??
                • Frenci
                  • Feb 2012
                  • 10
                  Is the developer yellow clear?
                  Or there is black contamination in the yellow developer housing?
                  • Nildera
                    • Nov 2014
                    • 13
                    everything is clear, I sent the machine for a preventive maintenance, was everything fine before it...
                    • Nildera
                      • Nov 2014
                      • 13
                      Everything was fine before I sent the machine for a prevent maintenance.
                      I belive that all the manchine is clean
                      I belive I need to calibrate the printer again...
                      I have this pages all the time
                      • Frenci
                        • Feb 2012
                        • 10
                        Sorry, my instructions were to the author of the post.
                        For your problem: IBT cleaner assy?
                        • Nildera
                          • Nov 2014
                          • 13
                          img157.jpgimg158.jpgI have the folow pages every time I start a new job
                          some one can help me please...
                          • Nildera
                            • Nov 2014
                            • 13
                            sorry but what you mean with "ASSY"
                            thanks
                            • Frenci
                              • Feb 2012
                              • 10
                              thanks
                              ASSY = Assembly.
                              The IBT belt cleaner is ok?
