xerox workcentre 5845 print and copy black
  • raulblanco
    • Apr 2014
    • 8
    hi
    Both in print and copies all the leaves out entirely in black. We changed the xerographic unit. Someone has happened to him ... any solution?
    Thank you
  • adriansto
    • 2388
    Black print means no charge on drum.
    • Exok
      • Jun 2011
      • 750
      Re: xerox workcentre 5845 print and copy black
      Check for poor connection of charge wires from the terminal block (on back frame that makes contact with the xerographic unit) to the high voltage power supply.
      If wires / connections are good, replace the high voltage power supply.
