Hello,can anybody help me on how to rest Xerox Workcentre 7228 Transfer Belt
  • archybos
    • Jan 2012
    • 24
    [Misc] Hello,can anybody help me on how to rest Xerox Workcentre 7228 Transfer Belt
    Hello,can anybody help me on how to rest Xerox Workcentre 7228 Transfer Belt, it showing order transfer cleaner
  • Iowatech
    Not a service manager
    • 3930
    Re: Hello,can anybody help me on how to rest Xerox Workcentre 7228 Transfer Belt
    More information, please.
    • adriansto
      • 2387
      Rest mens something else than RESET.
      For reset the IBT you must change 954-801 counter from HFSI to 0
      • Exok
        • Jun 2011
        • 750
        Press and hold 0 key for 5 seconds or longer then while still holding the 0 key, press the Start button.
        Enter 6789 and Confirm.
        Press the Log In/Out button.
        Select System Settings.
        Select Common Settings.
        Select Maintenance / Diagnostics.
        Scroll down to Adjustments/ Other.
        Select Initialize HFSI Counters.
        Enter the 6 digit code for counters to reset.
        954-801 = IBT Belt Assembly
        954-802 = 2nd BTR Unit
        954-803 = Transfer Belt Cleaner Assy
        954-804 = Fuser
        You can reset current value and you can also change the replacement threshold. Just max the count to 99,999,999. That way the item will work till if mechanically fails.
