DC 700 mottle 80gsm stock
  • Iowatech
    Not a service manager
    • 3930
    #16
    Re: DC 700 mottle 80gsm stock
    This might be stupid, but is there any chance you could share a picture or two of the print defect?
    The thing is, technicians might need visual input beyond a text description for accurate troubleshooting purposes. Also, there's people from all over the place here, and sometimes common words have slightly different meanings depending on where we are.
    Sorry if that was a waste of time.
    • azehnali
      • Nov 2009
      • 679
      #17
      post pictures
      • Nzer
        • Sep 2014
        • 34
        #18
        Originally posted by azehnali
        post pictures
        Here is pics of start of run (good), the 120 sets is not a bad as it gets, but have discarded the worse looking ones, I guess they were about another 50% again faded out before the run was stopped.
        • azehnali
          • Nov 2009
          • 679
          #19
          Have you tried to increase transfer in paper profile settings
          • Milo Wilson
            • 502
            #20
            Take a look at the backup roll inside the IBT assy. also. Check the contact points.
            • Nzer
              • Sep 2014
              • 34
              #21
              As previously posted, Have adjusted transfer voltages through in increments from min to max, Have tested with a complete IBT assembly.
              I think the most notable thing is that the job starts perfectly well and deteriorates over a few hundred sheets.
              • Scarecrow
                • Oct 2010
                • 234
                #22
                "I think the most notable thing is that the job starts perfectly well and deteriorates over a few hundred sheets.[/QUOTE]"
                And with only 80gsm of a particular brand? Does it run ok with regular 20lb? Or with heavier than 80gsm? Having a little trouble trying to follow this.
                • Iowatech
                  • 3930
                  #23
                  I may have missed something here, and if so I'm sorry about that, but is the cyan drum unit damaged? I know you said the image on the belt was good, and I've never seen this on Xerox equipment yet, but that looks a little like an ongoing bad drum ground or a drum charge failure from what I've seen on other machines.
                  • Nzer
                    • Sep 2014
                    • 34
                    #24
                    Thanks for your response - has had a new drums and bcr hvps - contacts o.k -
                    This fault only occurs when printing long runs of this set, (8 x 2 sided A3 with this image about A5 size being the only colour within the run the rest black only text)all other runs this cust does are short or heavy coverage. , can print the image in a run of several hundred by itself with perfect image on the 80 gsm stock
                    Although from what i can see the image on the belt looks good, I believe that the colour devs are being adversely effected with the long running time without toner down and the colour dev tanks turning ( have experienced this DC1000s and know nvms can be changed that alter the IQ adjustments which I think includes a dev clean routine)
                    I know this is getting long but - I can get the image to come good by stopping and running solid half tones and restarting job, As stated earlier it looks good on Colortech and heavier paper - I think it is just because of the rougher surface of the plain 80 gsm it looks a lot worse.
                    Maybe on the wrong path but have found limited info on this for 700s - to change nvms 762-396 ,407 - 409 to print dev bands at end of run, and 761-112 Print "dev band decay mid run", this has helped a lot - but not be completely ( now gets some mottle but nowhere near as bad), if any one has additional info on this area I would be interested - possibly how to increase the band time which is set for seven seconds, will be going back and testing by setting the job as a black job and adding the page with colour as an exception as this will stop the colour dev tanks turning all the time.
                    • Milo Wilson
                      • 502
                      #25
                      What firmware level are you on the DC 700?
                      • Nzer
                        • Sep 2014
                        • 34
                        #26
                        1.130.9
                        • Lee2475
                          • Oct 2014
                          • 48
                          #27
                          Have you tried reloading the IOT software?
                          • Milo Wilson
                            • 502
                            #28
                            You really should upgrade the firmware on your 700. it has had firmware fixes to take care of numerous problems and mottle is one. you are below the 1.1 version and it's up to at least 3.7
                            • Nzer
                              • Sep 2014
                              • 34
                              #29
                              This is a Fuji Xerox machine it has the latest, I know that Fuji run different firmware and naming to the U.S / Europe machines. - ( have reloaded )
                              I am awaiting test results of this job being run on another machine, will post outcome.
                              • Lee2475
                                • Oct 2014
                                • 48
                                #30
                                Well to be honest if your up the latest software level and reloaded it its an odd one, as said UK is now upto 3.7.
                                I have had issues with the ibt belt assembly on these, there is one other thing I have had that's caught me out and that's the clutch for the second btr retract, that's in the main drive, but normally you get faint copies after a run and I think this would happen on all paper, I'll have a hunt on our tips to see if I can come up with anything, I do feel for you I hate jobs like this.
