I was asked to look at a Xerox 7655 for a slow touch screen. It is for nonprofit that my wife volunteers with. Well to make it short, I fixed the touchscreen. I am not a Xerox tech, never serviced one before(I use to be a Canon tech for many years). So they primarily print in bw with occasional color. I noticed that there logo, the colors were missed aligned slightly. The magenta was off by .25mm or so. I found the service manual for the machine, and I ran the ADJ 9.8 Registration Control Setup cycle. Now the color registration is worse, ever color is off. So after searching online, I stopped the machine, and took the attached pictures, I am missing yellow chevrons on the front of the belt. I see the yellow developer plastic strip is messed up on the front of the machine as well. I'm at a loss were to go from here, they can't afford to have the machine serviced, so I got to try to fix it, and get the parts needed for this.
Any help on would be gratefully appreciated. Thanks!middle.jpgyellowdev.jpgfront.jpgback.jpg
