Paper jam problem with xerox 5645
  • Enzo
    • Jul 2009
    • 413
    hello friends. I have a paper jam problem with my xerox 5645.
    I enclose pictures of the problem.
    The paper is jammed in the area1.
    A technician told me that the problem is caused by the clutch (CL08-070).
    I changed it and the problem is solved. At first, the paper is still jammed, but after a little time the machine worked again.
    After 30 thousand copies, the problem has come back!
    Now I ask you ... is again the clutch? The clutch that I bought is new, not used!
    It may have broken yet? Is there some other reason? Thanks so much.
  • Lee2475
    • Oct 2014
    • 48
    Re: Paper jam problem with xerox 5645
    looks like its catching to me looking at the top of the paper, Have yot tried it from another paper tray?
    • Lee2475
      • Oct 2014
      • 48
      Also give me the fault history if your sure its not catching on anything in the paper path.
      • Enzo
        • Jul 2009
        • 413
        yes, friend! each tray to give the same problem!
        My fault history indicates only a problem with the paper sensors. But I have also excluded this problem as I have also changed the entire Group!
        • Lee2475
          • Oct 2014
          • 48
          Give me what codes you have and I can have a look on searchlite I've never had a problem with the sensors on the registration before only the one down the very bottom of the left side, does this do it every copy? You haven't got any codes for hvps? As I've had the same thing and it's been that, soon as it tries to put the image on the drum it faults out the paper stops about there, just a thought.
          Only thing to do it run component control and see if the sensors switch and the rollers turn under abit of load.
          • livewire
            • Sep 2011
            • 608
            Try to make copy from bypass.
            • Enzo
              • Jul 2009
              • 413
              The sheet from bypass will not start!
              • Enzo
                • Jul 2009
                • 413
                Now I do not remember the code number but I have the service manual and it indicates a problem with the sensors. I've already tried to run a check on the components, but it was positive
                • livewire
                  • Sep 2011
                  • 608
                  When you clear the jam, delete all print jobs.
                  Is the machine ready for work?
                  • Enzo
                    • Jul 2009
                    • 413
                    Exact
                    • adriansto
                      • 2390
                      It's clear the roller shaft nr. 25 from registration transport dont turn on.
                      So remove duplex tray then registration transport and check.
                      • Enzo
                        • Jul 2009
                        • 413
                        thanks friend. how I can locate exactly the roller nr.25?
                        you mean this: 059K60040 ?
                        I've already changed it with another one that works. it has worked for other 30 thousand copies and then the problem has come back!
                        • adriansto
                          • 2390
                          604K55570
                          • xeroxguru
                            Things to check for is the updated registration clutch the one way drive gears for the vertical transport and there is no binding in the registration rollers.
                            • Exok
                              • Jun 2011
                              • 750
                              It would help to know the exact jam fault code (such as 08-151). It does look like paper is being fed up the vertical transport then hitting the registration assembly that is not moving (or possibly not seated correctly).
                              Does the machine make any irregular noises when it jams? This can indicate a problem with the main drive unit. If the main drive unit is stalling it will not supply drive to the registration rollers and cause similar jams.
                              A new registration clutch should work fine for 500,000 copies or more. Did you use a new style clutch? It has blue wires not black.
                              I would start by removing the registration assembly.
                              Remove all gears from the rear of the registration assembly and inspect them for damage.
                              Remove all bushings from the roller shafts.
                              Clean the rollers and roller shafts and inside of the bushings.
                              Lubricate the ends of the roller shafts and inside of the bushings (replace any bushings that are worn)
                              Remove the top plate of the registration assembly that houses the upper registration roller.
                              Clean out the housing for the upper roller.
                              Clean the black plastic pieces that apply spring pressure to the roller shaft and lightly grease with plastislip grease as well as the 2 end caps for the roller shaft.
                              Reassembly the registration assembly.
                              Reinstall the registration assembly.
                              Take care to ensure that the small mounting hook on the front left side of the registration assembly is inserted inside the frame cut out so that the unit is not sticking up too high at the front end.
                              Take care to rout the ground wire that plugs into the upper registration plate at the front of the registration assembly so that it does not stick out into the paper path.
                              This should cover everything in the registration assembly that can be the cause.
                              Also, inspect the hinges on the left door assembly. If the hinges are cracked, you may not be getting good pressure from the vertical transport rollers to deliver the paper to the registration assembly.
                              Inspect the 2 sets of rollers in the vertical transport. The drive for these rollers can come loose and the rollers can shift toward the back. This lets the roller bearing at the front of the rollers to fall out of the frame. Shift them forward and back. Try to shift up and down. There should be no up or down play to the rollers if they are seated correctly.
                              The fact that your bypass try does not feed is interesting too. If nothing above helps, try to figure out why its not feeding, it might lead you to other discoveries.
