Paper jam problem with xerox 5645
  • Enzo
    • Jul 2009
    • 408
    Re: Paper jam problem with xerox 5645
    thanks friends for the answers. I have changed the whole "PL 8:15 Registration Transport", but the problem remains!
    Now I have to do the tests suggested by friend Exok.
    Also according to me is not a problem of clutch, but there is some mechanical problem!
    when the machine jams, it makes a sound as if the rollers rotate but do not take the paper.
    errors that give are: 08-100 and 08-150. But I do not follow these mistakes because, I repeat, I have changed the entire "PL 8:15 Registration Transport"
    • Lee2475
      • Oct 2014
      • 48
      I had the same fault yesterday, take the rear cover off the machine, remove waste toner bottle and holder, behind that there is a drive belt, mine had slid of the tensioner and was dragging this drives the registration rollers, but I realised this has it feed from the bypass without issues.
      08.150 was the code registration sensor, what it meant really was the paper was late getting there, didn't mean it wasn't working.
      • Lee2475
        • Oct 2014
        • 48
        This was 232 but there similar
        • Enzo
          • Jul 2009
          • 408
          #19
          hello my friends. I have done all the tests that you have suggested to me. The problem remains!
          All belts work! The only thing that remains is the main engine or some card.
          tomorrow I'll try with a new engine.
          • Exok
            • Jun 2011
            • 750
            #20
            If you suspect some roller is not turning, you can test it with the door switched cheated and using component control in diagnostics.
            • Enzo
              • Jul 2009
              • 408
              #21
              My friend, I have already tried this your solution. Everything runs perfectly, even manually!
              the only thing to change is the engine, I think! Tomorrow I will make this change.
              • xeroxsharp
                • Nov 2008
                • 270
                #22
                Check fuser drive gear on main drive assy
                PN 007K13202
                • Enzo
                  • Jul 2009
                  • 408
                  #23
                  PN 007K13202
                  thanks friend, but unfortunately this is not the problem!
                  • Enzo
                    • Jul 2009
                    • 408
                    #24
                    hello friends. I solved the problem! thanks to all for the help you have given to me. it broke the main motor. I hope I can serve it to someone else in the future.
