firmware issue
+ More Options
Posts
  • Riyadh hossain
    • Jun 2025
    firmware issue
    For firmware storing needs USB stick 1GB or less and FAT format .But now 1GB or less usb stick is not available in market ,
    Have any alternate way to store firmware files for firmware update????
    Sometime I use 4GB,FAT32 format but all time it does not work and vanish automatically, when I insert in pc,pc show need to format before using this device . Have any solution about USB stick for firmware update????? please help
  • adriansto
    • 2383
    Re: firmware issue
    What machine do you talk about ?
    • NeoMatrix
      Senior Tech.
      • 3514
      Re: firmware issue
      Dude, you may like to stop cross posting to mulitple forums.
      You'll have many "cross posts" coming back to you.
      For one, what machine are you having problems with?
      Some Ricoh and Kyocera machines work with one firmware file at a time on the SD/CF/USB stick. Try one firmware file at at time.
      Try formatting the USB stick to FAT only.
      • Iowatech
        Not a service manager
        • 3930
        Re: firmware issue
        Did you try to make the primary partition on the memory stick 1GB? If not, you should probably do that now.
