Getting sub system fault code/error machine stuck tried powering down unplug machine no help please help
can anyone help me my dc 5000 shows print engine sub system fault 9-343
Tags: None
Re: can anyone help me my dc 5000 shows print engine sub system fault 9-343
My PWS laptop edoc indicates the IBT belt home sensor not detected in time. Check the IBT reflective patch for damage. If 09-343 happens 3 times, reset nvm 741-743 to 0. If you don't have a PWS laptop, this machine is difficult to repair. I have a laptop available if you are interested. -
ROYBOY
my pws laptop edoc indicates the ibt belt home sensor not detected in time. Check the ibt reflective patch for damage. If 09-343 happens 3 times, reset nvm 741-743 to 0. If you don't have a pws laptop, this machine is difficult to repair. I have a laptop available if you are interested.Comment
thanks xtrain i had a copier copy come in and clean up the the machine which included the sensor now it seems we need to an authorized xerox personnel to reset nvm like u said with the chain link number do u have this and i probably would be interested in ur help with ur laptop
This machine requires a PWS laptop to link up, enter diagnostics, and reset the fault code. This process cannot be completed through the User Interface diagnostics built into the machine.Comment
