Help - Does the Light production finisher of the xerox 700 works on a xerox 560
Re: Help - Does the Light production finisher of the xerox 700 works on a xerox 560
It looks the same but it wont work. It will give a fault code or it wont get past the boot screen. -
If you check the serial # it should start with TKX (booklet maker) or MFA (no booklet maker). It can be used on a 4112/4127 DC 240/250/242/252/260 or DCP 700/700i/770.
The newer gen units have different hardware inside them. If you need one I may have one for sale. Interface Printers - Xerox Equipment - Wholesale Used Xerox Equipment - DealerComment
