Xerox DC250 Printing Defect
  • Phatman
    • Jul 2025
    [Misc] Xerox DC250 Printing Defect
    Hi Guys,
    This seems to be happening to me every 6 to 10 prints, its on 120gsm Colotech Gloss Coated Paper.
    Has anyone ever had the same problem or have advice on how to solve this. Image of defect below.
    Thanks,
    Damien
  • adriansto
    • 2388
    Re: Xerox DC250 Printing Defect
    A3 or A4 paper size ?
    • bojans
      • 1313
      I've seen this on DC 12, but never on DC 250.
      Looks like you have missing piece from belt.
      • Phatman
        Hi Guys thanks for the replys, Its A3 Paper
        • Phatman
          I could get 5 prints perfect then the 6th would have the defect, could that still be the belt? And only on coated paper
          • adriansto
            • 2388
            If the missing part of the image has the same shape the you must check for a piece of paper or something else in the belt area. Unscrew two bolts, pull out the IBT drawer and check. Also check in the 2nd BTR area.
            If you dont find anything the try to change the paper stock.
            • Phatman
              I will do that now. Really appreciate the help. Thanks
              • Phatman
                Well I found the problem. See Image. Now to replace this. Are they expensive?
                • adriansto
                  • 2388
                  Bojans was right !
                  You have a hole in the belt
                  • alex4alltimes
                    • Feb 2010
                    • 68
                    Queer things do happen....
