7435 fault code 124-709 and books will not go through booklet maker
  • nacnud
    [Error Code] 7435 fault code 124-709 and books will not go through booklet maker
    Have a 7435 w professional finisher. Books will not go through booklet maker but are redirected to center tray. Have fault code of 124-709 when I try to print fold position test sheet from Maint menu. Any thoughts or help would be appreciated...
  • xeroxsharp
    • Nov 2008
    • 270
    Re: 7435 fault code 124-709 and books will not go through booklet maker
    stapling unit is not moving
    drive belt is loose
    remove the front cover on finisher and you will see the stapling traverse motor and its loosen drive belt
