Xerox Workcentre 255 Stuck on Upgrade Screen!!!
Re: Xerox Workcentre 255 Stuck on Upgrade Screen!!!
Upgrade via CWIS (web page) using .dlm file and pre-upgrade patch or Altboot using PWS?
What is your SW version?
Why you upgrade your software?
UI change (looks like new)? -
Ui still hanged there!
i cant remmember sw version but it think 13.50Comment
First step you must do is to check 5 and 3.3 voltages on UI pwb and IPS pwb.
For 5 volts supply is good to have 5,1 volts and 3,3 V must have at least 3,4 -3,5 volts. If you have 3,3 or less volts the you must check LVPS and distribution pwb connectors from SIP cage.
May be you are lucky enough and the writing flashes processes was not started.Comment
