Xerox DCCII 3000
  • NeoMatrix
    Senior Tech.
    • 3514
    Xerox DCCII 3000
    What's the best method to access/remove the developer units from this machine ?
    Is there any issues with the dev units in this model ?
    tnx
    Neo
  • Nzer
    • Sep 2014
    • 34
    Re: Xerox DCCII 3000
    tnx
    Neo
    Remove right hand side cover then lvps and black plastic cover to access, there is one screw that is removed from the front that holds the dev tank in, may need to remove inner front cover to see which screw easier, and the locking release so the housing can be turned, they do have dev tank issues, the later tanks were modified to stop them losing dev during normal running, the problem is worse on machines running high volumes of black only.
    be careful that the black cover is refitted correctly or it may catch on the toner cart as they turn in the rotary Assy.
    • NeoMatrix
      Senior Tech.
      • 3514
      Thanks Nzer.
      I was hoping the rotary developer carriage could be removed as one entire assembly.
      It's tedious to get into for servicing the individual dev units.
