FreeFlow print server
  • Gbr
    • Nov 2011
    • 50
    [Misc] FreeFlow print server
    Hello
    Have a xerox dc260 with FreeFlow(6.0) print Server. Is there any manual or guides anyone can pass on?
    I had a lot of problem with this server, I needed to reset all passwords clear all queues from terminal, I also activated trial licenses.
    Now i'm having another problem with booting, it goes trough initial POST, allows me to choose which system to boot but then it gets stuck at
    "dc260 console login:_"
    Can anyone point me to solution.
    I tried different passwords, as service!, x-admin, administ,..
    Thank you!
    Regards
    Gbr
  • artphil
    • Aug 2008
    • 155
    Re: FreeFlow print server
    ROOT SA
    Originally posted by Gbr
    Hello
    [ATTACH=CONFIG]27232[/ATTACH]
    Thank you!
    Regards
    Gbr
    • print51
      • May 2018
      • 5
      Hello
      exactly the same problem and I happened
      Tell me how it can be fixed?
      Thank you.
      Hello
      Thank you!
      Regards
      Gbr
      • Milo Wilson
        • 502
        You have an issue with the type of monitor you are using. The software can't find the correct drivers for the monitor . Find an older 15 inch monitor and then try rebooting.
        • print51
          • May 2018
          • 5
          It worked with the same monitor...
          • Milo Wilson
            • 502
            What is the size of the monitor you are using? Try an older 15 inch monitor .
            • print51
              • May 2018
              • 5
              Monitor 15 inch Monitor
              • print51
                • May 2018
                • 5
                Now I need a license for FreeFlow 6.0
                can you help me?
                • print51
                  • May 2018
                  • 5
                  all made everything work ...))
                  all thanks for the help)
                  • exCSER
                    • Mar 2009
                    • 98
                    My apologies for hijacking this thread, but I have a question for Milo about this. How did you determine that the problem was caused by the monitor? Just curious.
                    T I A,
                    Don
                    • Milo Wilson
                      • 502
                      I've dealt with this issue before. Just experience.
                      • XeroxTechBrazil
                        • Aug 2008
                        • 199
                        can you help me?
                        Non-expiring licensing for most Xerox Free Flow servers available;
                        Upgrade to FF 7.xx and eliminate the monitor limitation, and enjoy support for wireless keyboard and mouse.
                        Better color support as well.
                        JorgeXcalak@live.com
