Xerox Colour 560 with 093-329
  • Piper
    • Apr 2011
    • 77
    Hi All.
    I have a Xerox Colour 560 giving a fault code 093-329.
    Supplies status is blank for all consumables and it indicates status: false when any consumable is selected in supplies.
    The EDOC does not have this RAP. Any experience?
  • adriansto
    • 2388
    Re: Xerox Colour 560 with 093-329
    Remove all toners. Power off the machine. Power on the machine.
    Insert toners one by one and watch when error appear. One of the toner CRUM si bad.
    • Piper
      • Apr 2011
      • 77
      Thanks Man.
      I had to replace all Toner CRUMS for Machine to work. Problem is Machine is on the Sold plan and we just buy the CRUMS to replace on the metered supplies which are available. Do you have the
      procedure and password for changing the consumable replacement plan?
      • adriansto
        • 2388
        The snippet file is linked to serial number of the machine.
        Only from Xerox you can get the snippet file for conversion.
        • mickeyb
          Many thanks for this,
          We have a C60 with same fault and this fixed it, has saved us some grief and saved Xerox sending out an engineer.
          Michael
          • fenave69
            • Jul 2009
            • 16
            Does anybody have the snippet conversion program
            • DheerajBE
              • Feb 2018
              • 39
              Any solution for Xerox dc 550 error code 093-329 ?
              toner chip life ends suddenly.
              www.viagrasansordonnancefr.com viagra france ordonnance
              • Jake2o
                • Dec 2007
                • 325
                The metered plan should run out on it's own eventually. You can find metered toner on eBay easy enough. It will give you a 30 day countdown before it switches to sold supplies on it's own.
                I had a custoner the other way round - the machine was on sold supplies but he went and bought a pile of metered consumables, so we found him replacement chips that made the metered supplies tell the machine they were sold supplies.
                • zanuyasir@gmail.com
                  • May 2022
                  • 1
                  Originally posted by DheerajBE
                  Any solution for Xerox 550 error code 093-329 ?
                  please help with error code on my xerox 560 I am using non metered toner but still got this massage I change cyan Developer also Change toner dispenser motor
                  machine work fine for couple of day then massage came up 093-329 and 093-316
                  Thanks in advanced
