Xerox C3545 Display Problem
  • Snoopy
    • Jul 2025
    [Electrical] Xerox C3545 Display Problem
    I moved a Xerox Workcentere C3545 home and now the display won't power up.
    The printer powers up a ways and the scanner powers on(fan anyway).
    I can't remember how or if the USB cables went and/or if there is some other problem.
    I ran one from the scanner to the rip which seems like the only real possibility but still no display.
    any help appreciated.
  • adriansto
    • 2387
    Re: Xerox C3545 Display Problem
    Yes the usb cable come from scanner to the controller but the display controller is power up by the voltage from main power source. Check the P/J's on to machine may be they are disconnected to the transport.
    Or may be the lamp that iliuminate the touch screen is dead or broken.
    May be the diagnostic WCPS software may help you to find the cause.
