Xerox DC12 help
  • alban_ks
    Xerox DC12 help
    i have e Xerox DC12 and i had a problem with System Fault and i solved that problem, but now the printer/copier does not print anything. It goes as always, like it should work, but in the end it is only a blank page coming out of printer. Can anybody help me about this problem.
    Thank you.
  • xcopytech
    • Aug 2006
    • 1794
    Check yellow lever under drum cartridge. Maybe is broken and do not push belt to drum.
    If that is ok call a tech
    • alban_ks
      thank you m8, it was exactly that what you said.
      Thank you again.
