WCPS Computer Advice: Problem with empty menue, no tabs visible
+ More Options
Posts
  • Dominik
    • Nov 2014
    • 10
    Hello everybody!
    I solved a problem some of you had already, I've seen print screens on the forum.
    Problem occurs when you start the WCPS / PWS software. There are no entries or tabs visible.
    That's not a problem with Windows 7 or other things.
    To solve it:
    1. You have to run Diagnav on compatibility mode "Windows XP" as administor. If you don't, there could aoccure faults by proceeding some commands.
    2. IMPORTANT! I don't know why, but you have to decrompress the Xerox folder on C:\ by right click on it and deactivate the checkmark on compress (in a folder sub menue).
    I tried it on two machines. Both times it worked.
    Please report if that could solve that problem on your devices, too.
    Greets from Heidelberg,
    Dominik
