5230 code 116-365
  • framza1
    • Nov 2014
    • 5
    5230 code 116-365
    xerox5230 fault codes 116-365 ?
  • Corder
    • Nov 2014
    • 105
    Re: 5230 code 116-365
    This is a spooler error. Usually it comes when problems in reading/writing internal HDD data occurs. You may try to initialize HDD, but if it happens again you'll need to order new HDD for your machine.
    To initialize HDD you must press simultaneously and hold the 4, the Stop, and the Power Save buttons and then power on the machine. That's all.
    • framza1
      • Nov 2014
      • 5
      Originally posted by Corder
      This is a spooler error. Usually it comes when problems in reading/writing internal HDD data occurs. You may try to initialize HDD, but if it happens again you'll need to order new HDD for your machine.To initialize HDD you must press simultaneously and hold the 4, the Stop, and the Power Save buttons and then power on the machine. That's all.
      thank you very much
