Sorry, just joined with problems - be kind :)
  • thespaniard
    • Jun 2025
    I just inherited a Xerox Docucolor 260 with a X3ETY controller which I am not familiar with.
    I plugged a monitor, keyboard and mouse into the X3ETY but get nothing on the screen. The LED panel at the back is showing 60. It does not have it's original PSU - just one from a another computer.
    On the DC260, it copies just fine but nowhere can I find the Network Settings button - even as admin (11111) or diagnostic (6789) there is no Network Setting button anywhere.
    I used CWS to scan the network but cannot see it on there so I suspect that it had different settings on it's previous network.
    Any thoughts and thanks in advance!
  • adriansto
    • 2384
    Re: Sorry, just joined with problems - be kind
    When the Fiery = X3ETY works good the display must show '00'
    60 code mean the faulty motherboard. Open the fiery controller and reseat memory, cpu, boards hdd cable and all connectors and after that try again to see what is happen.
    • thespaniard
      I took your advice and reseated the card and memory and now it starts up, flicks through some numbers and settles on 00.
      Now it comes up on the monitor with the Bios messages and stops at Loading the Kernal and then hangs
      I don't have any system disks so not sure what I can do?? It's an X3ETY-03
      Thanks!!
      • adriansto
        • 2384
        I sent you pm !
        • steveclv
          • May 2014
          • 95
          Does anyone else have v1.2 of the X3ETY software for the DC250?
          Thanks!!
