7120 System Software.
  • imagewalker
    • Jun 2010
    • 94
    Looking for System software for the 7120 Newest Version 71.23.23
    Xerox online only shows Version 71.21.21
    WorkCentre 7120/7125 Drivers & Downloads
    But this service update ( to fix scan to gmail fix ) says to download 71.23.23....Does this version even exist or is it an error????
    WorkCentre 7120/7125 Support
  • adriansto
    • 2388
    Re: 7120 System Software.
    Exist of course.
    Check your pm
    • imagewalker
      • Jun 2010
      • 94
      I have the v71.23.23 7120 system software now if anyone wants it for free.
      Still looking for the "NEWEST" Software version for the 7120 " v71.23.53 "
      I got scammed into buying an older version for $70 bucks after i did inquire
      (and mention) about a newer version. Now he wants another $50 bucks
      for the newest version.
      So the good guy that i am, I'im giving this one away for free.
      PS. Its newer than the one on the Xerox web site.
      IW
      • InterfaceP
        • Jun 2013
        • 488
        What about 71.23.43?
        • xeroxsharp
          • Nov 2008
          • 270
          I have 71.23.53 !!
          • Apouthe Donald
            • Mar 2014
            • 82
            hi I have a xerox 7120 that displays the code 116-312 need help thank you
            • imagewalker
              • Jun 2010
              • 94
              This is from the "7132 Manual", Sorry i don't have the 7120 Manual.
              116-312 HDD Encrypt Key RAP
              An error in the HDD encryption key is detected during boot.
              Initial Actions
              Power Off/On
              Procedure
              Check the HDD electrical connections (PL 11.2).
              If the problem persists perform Hard Disk Diagnostic Program.
              If the problem persists replace the HDD (PL 11.2).
              • Apouthe Donald
                • Mar 2014
                • 82
                thank you dear friend, but art can I have the technical manual to troubleshoot my email is: fredonaldy@gmail.com
                • Jim_Lafleur
                  Would you please pm me the 71.23.23 firmware or the latest?
                  • drewzif
                    • 101
                    I would really like the latest firmware also, have quite a number of these machines. Please PM me if you have it available.
                    • drewzif
                      • 101
                      Look what i found!
                      File Download: WorkCentre 7120/7125 SPAR Firmware, Version 71.24.03
                      • Filename WC7120_71.24.03.zip
                      • Version 71.24.03
                      • Date Mar 25, 2016
                      • Size 82.2 MB
                      _All Products File Download
                      • imagewalker
                        • Jun 2010
                        • 94
                        [QUOTE=drewzif;512353]Look what i found!
                        • Version 71.24.03
                        • Date Mar 25, 2016
                        • Size 82.2 MB
                        _All Products File Download[
                        IF THIS IS NOT A BAD FILE LET ME KNOW..........
                        • Jim_Lafleur
                          Originally posted by drewzif
                          Look what i found!
                          Wow! Thanks a lot!
                          Do you know if it fixes the issue with scan to email using SSL?
                          • drewzif
                            • 101
                            Originally posted by Jim_Lafleur
                            Wow! Thanks a lot!
                            What is the issue with scan to e-mail and SSL? I have seen an issue on the 5335 (basically the same software) when the e-mail settings are saved it changes to SSL, therefore you can't truly save a different setting. This can be changed on the user interface however after to disable the SSL. Every time you make any change in the web interface it will enable SSL so you have to disable it on the user interface.
                            I have never configured a 7120 for scan to e-mail so not sure if it does the same thing.
                            • mitza97
                              Hello.
                              I need too the latest firmware version.
                              And the procedure to flash the firmware to a non-functional machine which is blocked on the start-screen.
                              Thanks!
