message
  • Apouthe Donald
    • Mar 2014
    • 82
    message
    je travail sur une xerox wc5665 lors de la mise sous tension elle affiche se message: system unavailable. do not power down message appears. besoin d aide.
  • Lee2475
    • Oct 2014
    • 48
    Re: message
    need more info, What did you do to the device anything previous?
    • Apouthe Donald
      • Mar 2014
      • 82
      Re: message
      I xerox 5665 when powering it displays: system unavailable
      need help?
      • adriansto
        • 2383
        Re: message
        L'appareil est copieur ou multifonctions ?
        • Apouthe Donald
          • Mar 2014
          • 82
          • adriansto
            • 2383
            Re: message
            Disconnect the fireware cable from back of the scanner and remove the pci fireware board from scanner cage. Then power on the machine and it will start as copier only.
