Error Code 091-720
  • sgb8998
    • Nov 2013
    • 6
    [Error Code] Error Code 091-720
    Hi everyone,
    I'm having a problem with a Xerox ColorQube 8900 getting an error code 091-720.
    problem started when the drum blade came off, then started erroring out. Replaced the blade unit
    and took machine completely apart and checked all connections. Took printhead unit out and checked.
    Any suggestions of anything else that can be done? Don't want to replace the printhead not knowing if thats the
    problem. Any idea's would be greatly appreciated.
    Thank You
  • sgb8998
    • Nov 2013
    • 6
    Re: Error Code 091-720
    just wanted to let everyone know the problem was a crack in
    the printhead tilt cam.
