CLONE ON USB DISK FIERY V1 FROM BUILT-IN XEROX DC 250 - CLONER SUR USB FIERY v1 DC250
  • acl
    • Feb 2010
    • 32
    [Misc] CLONE ON USB DISK FIERY V1 FROM BUILT-IN XEROX DC 250 - CLONER SUR USB FIERY v1 DC250
  • adriansto
    • 2387
    Re: CLONE ON USB DISK FIERY V1 FROM BUILT-IN XEROX DC 250 - CLONER SUR USB FIERY v1 D
    Did you ............
    and version 1.2 for DC250 Fiery is the last.
    • acl
      • Feb 2010
      • 32
      Hi adriansto,
      thank you for your post, but yes I have read this documentation, and follow the steps, but I failled to succed.
      When I print the server configuration in the Server's Info that specificied / Software : EFI FIERY SYSTEM 6e - VERSION : 1.1
      Can I make an Ghost's copy from the HDD ?
      Thanks a lot.
      acl
      • acl
        • Feb 2010
        • 32
        Hi adriansto,
        I answer to fast at your suggestion.
        The link give me a different notice that I download previouly. Yours indicated that the Iso file name is "FCTe.iso", but I can't find on the EFI website. I just find FCT_forEmbeddedServers_2.1.
        Did you have the good one ? Can you mail me ?
        Thank you for yours enlightenment
        acl
        • acl
          • Feb 2010
          • 32
          The return,
          after reading the notice, without , I see that I have a system 6e and not an 8R2 (that was requirements)
          Somebody have a solution for my system
          Thanks a lot
          acl
          • bojans
            • 1313
            Originally posted by acl
            Hi,
            I try to clone my DC 250 BUILT-IN Fiery V1.1 on USB Flash disk, but i failled.
            I download the FIERY CLONE TOOL with the iso file "FCT_forEmbeddedServers_2.1", and I follow the procedure to create the USB flash drive.
            But when I try to make backup from the fiery server, i have an error, and nothing is done.
            Somebody can help me. Maybe I have the false iso file ? My DC 250 BUILT-IN Fiery is V1.1, but I find only the iso file "FCT_forEmbeddedServers_2.1"
            Somebody have a detail procedure ? more than the EFI support ?
            Thanks a lot
            ACL
            Hi acl,
            I'm not sure if I understood you.
            are you trying to reload software onto your bustled Fiery(for some reason, such corrupted software), or you're trying to make an image of your Fiery system(to put it onto other Fiery)?
            • acl
              • Feb 2010
              • 32
              Hi bojans,
              in fact I want to make a image of my fiery server to prevent some crash from my HDD. Now is old server but I want to continue to print on this dc250.
              I hope that I was clear.
              Bye.
              acl
              • bojans
                • 1313
                I really don;t know why you can't make that image. I suppose you did all the steps as described in manual.
                I dont know about you, but I have bunch of these machines in my contract, and have never made image of server.
                It takes half an hour to reinstall and setup the Fiery over ethernet.
                • acl
                  • Feb 2010
                  • 32
                  Hi,
                  it's the problem, I have no more contract on this machine, and I want to prevent some damage on my fiery server.
                  acl
                  • bojans
                    • 1313
                    Send me your email address.
                    • adriansto
                      • 2387
                      The easy way is to remove the hdd from Fiery, put it into an PC computer, boot the PC from a Linux Live Disk like Hiren's Boot CD ( google for it ) and make a whole Fiery hdd image using Clonezilla software.
                      • acl
                        • Feb 2010
                        • 32
                        Originally posted by adriansto
                        The easy way is to remove the hdd from Fiery, put it into an PC computer, boot the PC from a Linux Live Disk like Hiren's Boot CD and make a whole Fiery hdd image using Clonezilla software.
                        Hi adriansto,
                        thank you for the procedure and detail. I'm looking for trying this solution.
                        Bye
                        acl
