Service Mode Colorqube 9303
aikon
Re: Service Mode Colorqube 9303
Anyone Knows about error 092-805? I can't find nothing about this error! Thanks
Xerox Colorqube 9303Comment
92-805-00 Fuse A on the drum driver PWB has blown.
Check fuse A for continuity.
NOTE:
The fuse is located below PJ601 on the drum driver PWB and is marked F602. The fuse is non-reparable.
Fuse A is blown.
I will put together the steps for this procedure but you are most likely gonna have to get another board. I would strongly suggest that you purchase this part NEW not remanned or pulled from another machine. Reason is the Firmware maybe be different, on a new board it will come with the 2nd to latest firmware if not newest but will have version sticker on board.
Hope this helpsComment
aikon
NOTE:
Fuse A is blown.
Hope this helps
Thanks for the answer and help.
One more question, did you know some place that i can free download or buy the service manual and parts numbers?
Thank you one more time.Comment
joegates
