Xerox 700i error 010-319 can anyone help
  • 1mcfilhos
    • Mar 2013
    • 32
    I have a xerox 700i and i have the error 010-319 i have already chang the nvram 744-351 to 0 but same problem
  • xtrain
    • Dec 2012
    • 233
    Re: Xerox 700i error 010-319 can anyone help
    The 700i edoc says set nvm 744-316 to 0, not 744-315. It states to check fuser heat sensors and fuser drawer connector for bent pins, dirt, or burnout. Then to replace fuser assembly.
    • adriansto
      • 2387
      ?????????????????????? Realy ?????????
      • Corder
        • Nov 2014
        • 105
        Procedure
        It may be necessary to set NVM [744-361] to 0 in order to clear this failure.
        Check that there is no foreign object on the Heat Roll surface and no paper wound around it.
        Check the Fuser Sensors are free of dirt.
        Check that the Drawer Connectors connecting the Fuser Unit and the main unit are free from bent pins, foreign objects and burnout.
        Replace the Fuser Assy ( PL 8.1)
        • subaro
          • Oct 2010
          • 1274
          According to fault manual
          010-319 Fuser Center Thermistor Differential Amp RAP
          WorkCentre 7132Service DocumentationWorkCentre 7132705P01181 (EDOC/SGS)RevisionJanuary 2007
          troubleshoot the fusing unit, check the thermistors. and connectors.
          • Corder
            • Nov 2014
            • 105
            Man, 700i and wc7132 have little differences between each other
            • xtrain
              • Dec 2012
              • 233
              Thanks guys. I think he got the message.
              • subaro
                • Oct 2010
                • 1274
                Oh, I knew that, but just wanted to get the feedback. so here is a question. Is there a UI mode for the 700 and 700i and can a tech troubleshoot or test some functions of the machine in this mode.
                Just learning about this machine, so be patient.
                • Corder
                  • Nov 2014
                  • 105
                  Yes, of course.
