Xerox WorkCenter 4150, does this unit have scanning capability?
+ More Options
Posts
  • rdyjnkns
    • 135
    [Misc] Xerox WorkCenter 4150, does this unit have scanning capability?
    Good morning,We have a Xerox WorkCenter 4150 that we would like to set up for scanning. I have attached a copy of the configuration sheet. Under Installed Options, "Network Scan: Not Installed/Disabled" , I take it this is the option to either install the scan board (Installed) and if it is installed, I can disable this service. Under Network Scanning Setup, "Network Scanning Enabled: Enabled", scanning is enabled. Our question is does this unit require either a scanner board and/or firmware license for network scanning.Your assistance would be deeply appreciated. V/RRudy
  • Corder
    • Nov 2014
    • 105
    Re: Xerox WorkCenter 4150, does this unit have scanning capability?
    WorkCentre 4150 098S04929 Genuine Xerox Supplies
    • rdyjnkns
      • 135
      Thanks for the reply. BTW, are these Network Scan Enablements transferable between units (can I take one from a non-functioning 4150 and put it in a functioning 4150)?V/RRudy
