DC 6060 subsystem fault 009-357
  • Kaz73
    • Mar 2015
    • 20
    [Error Code] DC 6060 subsystem fault 009-357
    Hi I have a subsystem fault 009-357, I think the code is dispenser 4 is broken, can anybody tell me what dispenser 4 is please and how to fix.
    Thanks in advance
    Kaz
  • xtrain
    • Dec 2012
    • 233
    Re: DC 6060 subsystem fault 009-357
    My PWS edoc says black toner dispenser fault. Check DC330 9-017 for toner cartridge motor runs, 09-021 for dispenser motor runs and dispenser gears turn. Vacuum K toner housing and reinstall cartridge. You need a PWS laptop to repair this machine.
    • Kaz73
      • Mar 2015
      • 20
      Thanks Xtrain, your helps really appreciated, I thought it had something to do with the black as I have just replaced the cartridge.
      Thanks again
      • tasosGR
        • Jun 2014
        • 23
        Thanks in advance
        Kaz
        Reset the NVM 755-037(Y), 755-038(M), 755-039(C), or 755-040(K) to 0 like the associated RAP tells you. In addition, also reset 755-020 (Y), 755-021 (M), 755-022 (C), or 755-023 (K) to 0, depending on which color had generated your fault. Exit diagnostics and perform a PO/PO. This will solve the problem unless there is still an actual mechanical dispensing or sensing problem.
