dc-12 weird problem
  • funnykishi
    comp technician
    • Mar 2008
    • 19
    dc-12 weird problem
    Hi,
    One my dc-12 when pinging at machine's IP address it respond normally (reply correctly) but sending print command from computer pinging stops and not print comes out.
    I have changed networking cables
    Can anyone helps me
    Thanks in anticipation
    Regards
    Brij Mohan Sharma
  • alex4alltimes
    • Feb 2010
    • 68
    Re: dc-12 weird problem
    Originally posted by funnykishi
    Hi,
    Can anyone helps me
    Regards
    Brij Mohan Sharma
    Did you print to Port 9100 or to SMB? In both cases you must place the IP of the Fiery to the same workgroup, like MSHOME or WORKGROUP. See if you can access the HOLD queue from the Network Connections. If yes, then double click and install an instance of the HOLD queue as a printer. If no, then check the domain in the fiery and set it to the same domanin as your computer. Is your Computer running Windows 7?
    • funnykishi
      comp technician
      • Mar 2008
      • 19
      I am printing from this machine for the last two years but before 10 days I have lost power in my shop and resulting in this problem
      Yes , i can see print queue from network but printer not print anything.
      I have windows xp installed in my computer.
      • alex4alltimes
        • Feb 2010
        • 68
        Hi, Can you access Command Workstation? Can you print from there?
        • funnykishi
          comp technician
          • Mar 2008
          • 19
          I can access machine from network but unable to print from anywhere.
          Thanks for your reply
          • funnykishi
            comp technician
            • Mar 2008
            • 19
            can anyone provide me xerox DC-12 cobra rip software and machine firmware to reinstall on my machine.
            Thanks in anticipation of help
            Regards
            • adriansto
              • 2392
              Cobra 2 GoldenGate v.3, firmware7.06 or 11.50.3
              • funnykishi
                comp technician
                • Mar 2008
                • 19
                I have attached previous configuration which I have saved when machine works.
                Can anyone help to install cobra software and machine firmware .
                My email id is funnykishi@gmail.com
                any help appreciated.
                • adriansto
                  • 2392
                  Sent you mail with what I have for DC12
                  Your machine is FU2 type for XC market region.
                  • WIWA
                    • Mar 2009
                    • 97
                    Hello,
                    Sorry to tell Cobra is the Crabby-patties interfaces for those copiers , If you don.t want connectivity problems , use a Fiery X12 instead you can get one at E-BAY and convert you machine to a DC12 just changing few NVM's values and few adjustments did on mine and working like a charm . I you want a cobra ( not sure is still working for parts) can sell mine for 50 buck plus shipping to your destination .
                    hope this help,
                    Wiwa 72 , Gonzos build v.1.0
