Xerox DC5000 error code 9-335
  • gudasrudas
    • Jul 2025
    [Error Code] Xerox DC5000 error code 9-335
    Hi Xerox guru,
    Pls help with error code " Print engine subsystem fault 9-335" (DC5000)
  • adriansto
    • 2386
    Re: Xerox DC5000 error code 9-335
    Originally posted by gudasrudas
    Hi Xerox guru,
    Check if the waste bottle is full with residual toner.
    If not then collect auger nr 1 is broken or the waste duct C/K is blocked.
    • gudasrudas
      Big Thanks Adriansto for prompt response
      • tasosGR
        • Jun 2014
        • 23
        change NVM 755-808 to a "0"
        • xtrain
          • Dec 2012
          • 233
          Run DC330 009-124. Check if waste toner augers 1 & 2 rotate. DC330-106, check auger #1 sensor for changing high/low state. After repair, NVM 755-808 (sensor #1) must be reset to 0. I think you will need a PWS to fix this.
