Xerox 7345 All Color Band Print Fault
  • netbaba2000
    • Jul 2014
    • 21
    [Misc] Xerox 7345 All Color Band Print Fault
    hi.
    I have Xerox WC 7345 from today morning i am facing problem with my machine (all color band print ) on paper front and back side.
    till last night every thing is oke.
    same problem with color xerox.
    Please help me to find out.....
    ( Sample Image is Attached )
    Thx
    Prashant
  • adriansto
    • 2386
    Re: Xerox 7345 All Color Band Print Fault
    Probably High Voltage Power Supply with problems.
    Can you tell us the error code from machine faults history ?
    • netbaba2000
      • Jul 2014
      • 21
      Hi
      yes high voltage fluctuation is big issue in my city.
      this is all my machine error/fault log attached.
      010-354 Sub Heater Warm Up Fail ( Today Morning fault )
      010-348 Main Heater Over Heat Fail
      026-714 Bypass Tray Issue
      016-600 KO Authentication Locked
      027-516 Server Connection Error
      018-543 SMB Error
      026-714 Bypass Tray
      008-152 Sensor Jam Tray No 4
      007-119 Tray 4 Mis-Feed
      018-543 SMB Error
      rest of error related with network / paper jam / and fax issue.
      • adriansto
        • 2386
        There isnt errors related to HVPS.
        However the fuser errors can be from a problematic LVPS.
        Check the voltages on the machine.
        • netbaba2000
          • Jul 2014
          • 21
          Hi
          As your first reply i checked all pcb and voltage and i found this is 5v LVPS error all three Lvps condancer is open ( 330mfd 200V ) all cond is replace with same value and problem is solved.
          Thanks for yours support all team are great.
          bye.
          • adriansto
            • 2386
            Welcome !
