Xerox 5645 Will not come to "Ready"
  • Printercylr
    • Aug 2025
    [Misc] Xerox 5645 Will not come to "Ready"
    Greetings to all, My name is Steve. And today I am faced with a problem ...Xerox 5645. Once turned on, It will Only initialize. It will not come to Ready. How can I re-boot this machine to erase or get into the System's Service mode to see what is causing this? What do I need to perform prior to this? Everything was inspected....Tnak you in advance, Steve
  • adriansto
    • 2392
    Re: Xerox 5645 Will not come to "Ready"
    What kind of machine is - it have a controller situated lower back side of machine and connected with fireware cable to the back of the scanner module or it's a Single Board Controller machine.
    What software version ?
    • Printercylr
      I did not inspect this unit yet, .I will supply you with more info in a few days...Steve
      • Printercylr
        Information that I have is that It "does" have the corded connection from the lower side to the back of the scanner. I am still finding out what version of Software it is using. I will keep you informed....Steve
        • adriansto
          • 2392
          Most common cause is the network controller dont boot-up.
          Corupted net controller software, bad hdd, bad power supply of the controller, defective ram simm memory.
          There is a diagnostic software named altboot to check the status of the controller and reload the software.
          Two major software version xx.113.xxxx or xx.120.xxxx
