xerox pws to DC-12 How to
  • funnykishi
    comp technician
    • Mar 2008
    • 19
    Can anyone help me to install cobra fiery software of DC-12
    I have GSN software and DC-12 Software but unable to connect to DC-12 and does not understand how to install software.
    Any help would be appreciable.
  • WIWA
    • Mar 2009
    • 97
    Re: xerox pws to DC-12 How to
    Hello ,
    Well first of all you should have a laptop with serial and parallel ports , Dell 630 does a good job with parallel interface via pcmca (check on E-Bay). The serial is for diagnostics and the parallel in conjunction with serial for firmware uploads. But most of the diagnostics can be done Via UI , just in case.
    Hope this help,
    Wiwa 72, Gonzos build V. 1.0
    • funnykishi
      comp technician
      • Mar 2008
      • 19
      no one want to help me
      strange
      any help would appreciated ,
      • WIWA
        • Mar 2009
        • 97
        Originally posted by WIWA
        Hello ,
        Hope this help,
        If you have all the software related no problem to help you you should check if you have installed the diagnostic software for the DC 12 also need a serial cable to hook up you laptop with the serial port on the machine one side male the another side female . by the way if your in a hurry use the UI diagnostics you will be capable to do diagnostic inthere.
        hope this help,
        Wiwa 72, Gonzos build v.1.0
        • funnykishi
          comp technician
          • Mar 2008
          • 19
          I need to installed cobra fiery software
          can you help me to installed software in it.
          • tasosGR
            • Jun 2014
            • 23
            FOR COBRA SOFTWARE:
            You need only a cd (cobra software 165)
            You must put this CD to the cdrom of cobra and let it to finish the installation.
            You don't need any other way (pws,....)
            • Enzo
              • Jul 2009
              • 413
              Exactly! No need to pws . You must use only the cd to be put in the Cobra . I'm sorry I did not help but I have experience only on x12 fiery .
              • funnykishi
                comp technician
                • Mar 2008
                • 19
                can anyone have cobra fiery software.
                • funnykishi
                  comp technician
                  • Mar 2008
                  • 19
                  can anyone help me ?????
                  Thanks in anticipation
                  • adriansto
                    • 2387
                    I sent you PM some days ago.
