WorkCentre 7655 "Accumulator belt home position took too long" message
  • rockdude
    • Feb 2011
    • 257
    I took the belt off, cleaned the inside and outside (especially the silver patch)
    Blew out toner from IBT frame and all sensors.
    Reset NVRAM back to zero after the message appeared three times.
    Tested IBT belt motors.
    The only motor that didn't sound right was the steering motor (just a kind of buzzing sound) but I didn't remove drum units before
    testing.
    I am not sure if I should replace the entire IBT assembly or just gamble on the steering motor.
    Any help would be appreciated.
  • tasosGR
    • Jun 2014
    • 23
    Re: WorkCentre 7655 "Accumulator belt home position took too long" message
    testing.
    Tell me your fault is 042-326?
