xerox 252 not printing cyan anymore
  • mpsolutions
    • 25
    Hi everyone,
    I just changed the MOB sensor on my xerox 252 due to a faulty misregistration problem, and now the machine does not print cyan anymore.
    Is this related to the MOB sensor? Registration is perfect now, but I still get all NEG on regisrtation procedures. How is that possible?
    Any idea about the problem with the missing cyan.
    By the way, I changed IBT belt and put new cyan drum, still same problem.
    your Help is very much Appreciated.
  • tasosGR
    • Jun 2014
    • 23
    Re: xerox 252 not printing cyan anymore
    Originally posted by mpsolutions
    Hi everyone,
    Take a look at the cyan housing gears (inboard gear)
    • mpsolutions
      • 25
      I removed the developer cover and cheated the fornt door, the developer gears seem to run just fine, what else do I need to check.
      • tasosGR
        • Jun 2014
        • 23
        1. Enter the Diagnostic Mode. Refer to Entering PWS Diagnostic mode.
        2. Select dC675 from the DC Quick menu.
        3. Select Start.
        • mpsolutions
          • 25
          3. Select Start.
          Is this done thru PWS (I dont have one), or it can be done thru the touche screen, and How?
          • tasosGR
            • Jun 2014
            • 23
            1.
            • mpsolutions
              • 25
              I did the Registration Control-setup cycle as requested. Now the machine is printing out of register again. And still not printing cyan.
              Help!!!
              • tasosGR
                • Jun 2014
                • 23
                Hi everyone,
                You must check IBT frame (inside ibt belt), because your problem start when you replace ibt belt.
                Check 1st BTR.
                • adriansto
                  • 2388
                  First step is to go into sevice mode and choose cyan 50% test print on A3 format.
                  Select execute then panic stop the machine while printing the test.
                  Open the drums drawer and check if there are cyan toner on cyan drum.
                  If exist then go to the ibt and check for btr1.
                  If no toner at all on cyan drum then the problem can be from defective cyan drum, defective developer unit or lack of voltage on dev unit.
                  In the worst scenario there is a problem with cyan ( laser unit ) ROS
                  • mpsolutions
                    • 25
                    There is no cyan toner on cyan drum.
                    i have already changed the cyan drum and the cyan developer housing from another machine.
                    so the only thing left to check is the lack of voltage on the developer unit.
                    how do I check that?
                    • adriansto
                      • 2388
                      You don't have already a service manual for this copier ?
                      • mpsolutions
                        • 25
                        No, unfortunately not.
                        the machine was fixed by xerox tech. But no longer since 6 months ago.
                        • adriansto
                          • 2388
                          It's time to purchase one and follow the service procedure from there.
                          • mpsolutions
                            • 25
                            Update: the tech was here today, checked all the gears and Mechanics and changed Cyan developer. Now he is sure it's a voltage problem.
                            Because the machine prints a rough surface blue on whole sheet.
                            According to him, he never encountered this problem, and does not know how to fix it.
                            Any ideas?
                            • xcopytech
                              • Aug 2006
                              • 1794
                              Check developer bias contact as on attachment pictures.
