WorkCentre 5325 Networking
  • dsgoody
    • May 2025
    Hello all,
    We have a Xerox WorkCentre 5325 that we need to get networked (it's been standalone up until now). While it has a network port on the back and plugging a cable into it shows a network link light all of the configuration options are missing from the Admin interface.
    Has it been disabled? If so, how do we go about re-enabling it?
    Cheers,
    Dave.
  • acfife
    • May 2012
    • 63
    Re: WorkCentre 5325 Networking
    Originally posted by dsgoody
    Hello all,
    Cheers,
    Dave.
    http://download.support.xerox.com/pu...n_guide_en.pdf
    Enabling TCP/IP
    Note:
    By default, TCP/IP is enabled. If you disable TCP/IP, you must enable it at the printer control
    panel before you can access CentreWare IS.
    1. At the printer control panel, press the
    Machine Status button, then touch the Tools tab.
    2. Touch
    Connectivity and Network Setup > Protocol Settings.
    3. Touch
    TCP/IP - IP Mode, then touch Change Settings.
    4. Touch
    IPv4 Mode, IPv6, or Dual Stack to enable both IPv4 and IPv6.
    5. Touch
    Save.
    • dsgoody
      Cheers for the response acfife. I have checked through the manual, but these configuration options are missing from the copier.
      • Flash
        • 378
        You need to log in as administrator first. Press the Log in/ Log out button. user name is admin password is 1111.
