xerox 7132
  • sparks
    • Jun 2025
    [Misc] xerox 7132
    Need service manual for part number. Xerox WorkCentre 7132.
  • xtrain
    • Dec 2012
    • 233
    Re: xerox 7132
    You can download it as a PDF for $9.95 at smpcshop.com.
    • Corder
      • Nov 2014
      • 105
      Re: xerox 7132
      What part exactly you're in need for?
      • sparks
        Re: xerox 7132
        IBT Transformer belt.
        • Corder
          • Nov 2014
          • 105
          Re: xerox 7132
          Not sure what means "Transformer" but there's some:
          064K92400 IBT Belt Assembly (for whole unit)
          064K92330 IBT Belt (for belt only)
          • sparks
            Re: xerox 7132
            Thanks a lot. Had another problem on my mind I meant "Transfer belt."
            • JohnCo
              • Apr 2015
              • 13
              Re: xerox 7132
              I am going behind another tech. The machine was working just dirty copies in black. After the developer change the copies went lite. We had problems with the IBT belt. I bought a parts machine but the HD was missing.After swapping thew HD we figured that was not possible.Now the machine is throwing all sorts of codes. I am picking up the HD tomorow and will install firmware in the parts machine sinve it was in better shape.
              I contacted smpcshop for a manual and waiting to hear back.
              After I figure this out I will have a 7232 parts machine with a bad belt if you need anything else contact me through this post.
              Good Luck all around .
              John
              • Apouthe Donald
                • Mar 2014
                • 82
                Re: xerox 7132
                which puts the machine code
                • Cam
                  Re: xerox 7132
                  John
