xerox 7435
Re: xerox 7435
Man, if you need help you must be more specific. At least point to work mode, are you encountering problems when printing or scanning, and it helps if you attach the sample of print or scan job. -
Re: xerox 7435
I must admit I had to look and read several times. I think his issue is that he wants the image to be centered on the paper. This should be a simple image adjustment in the CE mode.Comment
