worrng fully supply 220 volt in xerox 7345 (110v)
  • BLACKSHARMA
    • Feb 2013
    • 6
    [Error Code] worrng fully supply 220 volt in xerox 7345 (110v)
    worrng fully supply 220 volt in xerox 7345 (110v) now this machine is showing error like 009-383,380,382 and after NVM reset one or two copy ( diagonal bar type print ) come out and then code is come
    i don't have circuit diagram of Xerox 7345 can any one Provide me
  • zuojin168
    • Sep 2012
    • 83
    Re: worrng fully supply 220 volt in xerox 7345 (110v)
    Please check the power supply and high pressure.May need to replace the high-pressure PCB
    • xtrain
      • Dec 2012
      • 233
      SMPCSHOP.COM has the service manual in PDF form for $9.95.
      • BLACKSHARMA
        • Feb 2013
        • 6
        CAN U EXPLAIN HIGH PRESSURE PCB
        • adriansto
          • 2384
          He wanted to say High Voltage Power Supply Printed Wired Board = HVPS PWB
          • xtrain
            • Dec 2012
            • 233
            [ATTACH=CONFIG]29027[/ATTACH]
            If you order the inexpensive service manual from smpcshop.com, you will get the electrical schematics, parts list, and everything else needed to service the WC7345. You must download the 2062 pages and print the manual yourself.
            • BLACKSHARMA
              • Feb 2013
              • 6
              thanks all
              Two of HVPSP condenser replaced ( PCB Repaired ) and problem solved
