DC252 Yellow background on copies only
  • CopierTechofOmens
    Agitating Artificer
    • 268
    [Electrical] DC252 Yellow background on copies only
    Scan001.PDFScan001(1).PDF
    Copies have yellow background no visible yellow image. Prints come out fine, just fine.
    Ran all setups which complete without error.
    Updated system software, reset NVM, cleaned all connections, cables, Replaced ROS, Developer Housing, and BP PWB
    sigpic
  • InterfaceP
    • Jun 2013
    • 488
    Re: DC252 Yellow background on copies only
    Preform an Auto Gradation for starts.
    • CopierTechofOmens
      Agitating Artificer
      • 268
      All adjustments performed according to manual
      sigpic
      • adriansto
        • 2388
        Did you performed the IIT/IPS tests pattern ?
        • CopierTechofOmens
          Agitating Artificer
          • 268
          Yes those also have yellow backgroundScan001(3).PDF
          sigpic
          • adriansto
            • 2388
            Try another chart test 82Exxxx.
            Never seen a CCD so uncalibrated
            • CopierTechofOmens
              Agitating Artificer
              • 268
              It's also not the CCD (Lens Assembly)
              sigpic
              • zuojin168
                • Sep 2012
                • 83
                This like yellow charging bar (drum)
                If change the yellow drum unit also appeared the same problem,
                Check the drum unit at the back of the charging part (spring)
                • InterfaceP
                  • Jun 2013
                  • 488
                  Curious to know if you got it figured out.
                  • CopierTechofOmens
                    Agitating Artificer
                    • 268
                    The correct answer was ESS PWB. Thanks for playing.
                    sigpic
