Xerox DocuCentre IV C2260 bad image
+ More Options
Posts
  • Alex1
    • Oct 2012
    • 285
    Hi,
    i have a Xerox DocuCentre IV C2260 that I relocated, prior to relocation it was printing perfect after the relocation this is what the machine is now printing please see attached image
    black is very faint
    colour puts a yellow tinge over the page
    cyan is faint
    magenta is faint
  • zuojin168
    • Sep 2012
    • 83
    Re: Xerox DocuCentre IV C2260 bad image
    Check the developer is there, then check that the drum unit.
    I found you this is not black
    May be activated first unit out of the question.
    • Alex1
      • Oct 2012
      • 285
      The drums and developer are good. Especially the Black I installed new.
      i tried different Colour drums and tried a different ITB still the same
      • zuojin168
        • Sep 2012
        • 83
        Laser unit (LED) check?
        Have you tried to put battery processing?Or all clear
        NVM clear
        • copytech200X
          • 264
          pls print test pattern 59 for all individual color 40 % each ..if are same problem then ROS Assy .
          • Alex1
            • Oct 2012
            • 285
            How would I perform that please. The ROS would that be the octagon that rotates would that need to be reaseted in the laser ?
            • copytech200X
              • 264
              go for ui diagnostics 0 + Start then password 6789 ....go for test pattern print to isolate print issue for all individual color 40 % each .
              • Iowatech
                Not a service manager
                • 3930
                The test print is found in the test mode for the machine. I am not trained on this model yet, so I don't have access to the test modes you need.
                Unless the machine was handled overly harshly during the time you were moving it, I'm not sure the spinning octagon you speak of would be the problem though. On the machines I do work on, the ROS is the entire laser unit, and the motor that drives the octagon is pretty securely fastened in the ROS.
