i have a 7545 always have the problem 116-324 any answer for that thanks..
7545 print document fault 116-324
Re: 7545 print document fault 116-324
this is driver problem
You need special boot modes to erase this masege
POWER OFF your 7345,disconect network cabl, press and hold for 20 secs. ( 6,STOP,POWER SAVE ) while you power on you 7345,
instal new print driver from Xerox Business Services, Digital Printing Equipment use GLOBAL PRINT DRIVER
use GPS driver if your 7345 has PS ram install,or GPCL driver if xerox do not has PS ram
